Knzych
Feb 21, 2019Initiate
R7800 is giving wrong gateway to wifi device
I bought a R7800 yesterday, It works well on the lan connection. However, there is a weird problem on the wifi connection, the default gateway was set to 192.168.1.1, But those wifi connected dev...
- Feb 21, 2019
i just solved
but still thanks for your help.
Its due to the secureNAT from softether
hope anyone who encounter this issue can solve through turning it off
microchip8
Feb 21, 2019Master
do you have a modem-only or a gateway (modem+router) in front of the R7800?
- KnzychFeb 21, 2019Initiate
i just solved
- michaelkenwardFeb 21, 2019Guru - Experienced User
Well done.
Can you explain what that does? It might help someone who hits a similar issue.
What is it for?
