Knzych
Feb 21, 2019Initiate
R7800 is giving wrong gateway to wifi device
I bought a R7800 yesterday, It works well on the lan connection. However, there is a weird problem on the wifi connection, the default gateway was set to 192.168.1.1, But those wifi connected dev...
- Feb 21, 2019
i just solved
but still thanks for your help.
Its due to the secureNAT from softether
hope anyone who encounter this issue can solve through turning it off
Knzych
i just solved
michaelkenward
Feb 21, 2019Guru - Experienced User
Well done.
Can you explain what that does? It might help someone who hits a similar issue.
What is it for?
