Drez143's avatar
Drez143
R7800 is limiting network upload speed
I began noticing that my Nighthawk R7800 is limiting the upload speed of the devices on my network.  If I run a speedtest internal to the router, the router sees my service speed of 100/100 (roughly...
  • mymedsdontwork's avatar
    mymedsdontwork
    May 25, 2019
    Same on my R7000P.  It's a problem with Ookla Speedtest.net which shows Upload speed as 25-50% of Download speed for the past week or so.
    Try Speakeasy,net or DSL Reports Speedtest and you'll get your actual DL & UL speeds.
    Something's definitely wrong with the Speedtest.net website.
