Drez143
May 25, 2019Aspirant
R7800 is limiting network upload speed
I began noticing that my Nighthawk R7800 is limiting the upload speed of the devices on my network. If I run a speedtest internal to the router, the router sees my service speed of 100/100 (roughly...
- May 25, 2019
Same on my R7000P. It's a problem with Ookla Speedtest.net which shows Upload speed as 25-50% of Download speed for the past week or so.
Try Speakeasy,net or DSL Reports Speedtest and you'll get your actual DL & UL speeds.
Something's definitely wrong with the Speedtest.net website.
mymedsdontwork
May 25, 2019Initiate
Drez143
Touche, my speed test looks correct on speakeasy.
