Nebakanezzar
May 09, 2022Initiate
R7800 is maxing out at ~100Mbps
Hi, My R7800 seems to be maxed out at 100Mbps on the 2.4ghz band, but i am getting the full 500Mbps with the 5ghz band. I have updated to the latest firmware and that did not help. can an...
Nebakanezzar
Ah, ok, didn't know that!
the R7800 says it get speeds up to 800mbps on 2.4ghz...what a bunch of BS false advertising!
May 09, 2022Guru - Experienced User
Those are connection rates seen between the router and connected devices that support connection rates at those speeds. Connection rates differ from actual bandwidth...
Not alot of wifi devices that support 800Mbps on 2.4Ghz.
