crocr76
Jan 13, 2024Aspirant
R7800 keeps dropping its Internet connection
My router (R7800 Nighthawk) is updated to firmware 1.0.2.92. I have a TP-Link EAP 110 Outdoor access Point connected to it, and a KuWfi 300Mbs bridge connected to a 8 port gigabit switch. I also have...
- Jan 15, 2024
Hi all - I just wanted to report back after monitoring the system for the last 24 hours +.
The problem has been solved - clearly it was an issue with having 2 DHCP servers running, and since I reconfigured the bridge units without DHCP active and with Static IP addresses, everything now seems to be working fine.
Thank you all so much for your help in troubleshooting this, and I am very happy that the R7800 now seems to be doing the job I hoped it would. Cheers
Kitsap
Jan 14, 2024Master
Be sure and report back after you get some hours on your new configuration.
Did the warning message from your Fing Network Scanning App go away?
crocr76
Jan 15, 2024Aspirant
- KitsapJan 15, 2024Master
crocr76 wrote:Hi all - I just wanted to report back after monitoring the system for the last 24 hours +.
It is good to hear you have things working as expected.
Now that you have your feet wet with the R7800, you need to check out the firmware from Voxel here:
https://www.voxel-firmware.com/Downloads/Voxel/html/index.html - check under X4S.
Be sure and review the README information at the top right.
If you have any Netgear warranty left on your device, installing Voxel will make it void.
There is an active Netgear forum over on Small Net Builders here:
https://www.snbforums.com/forums/netgear-ac-wireless-wi-fi-5.53/
- crocr76Jan 15, 2024Aspirant
Thanks for the info - I'll check it out. Much appreciated
