DickCB
May 23, 2022Follower
R7800 looses looses Static IP setup
My two year old R7800 randomly loses my ISP’s static IP address setup. I have had up times of as much as 2 weeks, but lately it is likely a couple of hours. I have reset the R7800 and manually ente...
Kitsap
May 24, 2022Master
I too would recommend the Voxel firmware. I have been using it for several years with outstanding results. If you do not like it, it is easy to go back to Netgear stock firmware.
Here is the start point: http://www.voxel-firmware.com/Downloads/Voxel/html/index.html .
Recommend you take a minute to review the Read Me file.
