ChrisPl
Mar 30, 2023Aspirant
R7800 loss ping
Hello I have r7800 with firmware V1.0.2.92 installed. Do other users of this device have the same as me? I am connected via LAN cable. When pinging the world with an interval of 0.5 second...
Mar 30, 2023Guru - Experienced User
What kind of pings do you see if directly connected to the ISP modem?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
