ChrisPl
Mar 30, 2023Aspirant
R7800 loss ping
Hello I have r7800 with firmware V1.0.2.92 installed. Do other users of this device have the same as me? I am connected via LAN cable. When pinging the world with an interval of 0.5 second...
Mar 30, 2023Guru - Experienced User
like FURRYe38 says, what modem/gateway is it connected to.
Your ping from host to router is fine. So its router to getway is where I'd start
- ChrisPlMar 31, 2023Aspirant
Look how my old draytek 2110 router is running.
mtr -i 0.5 -s 1500 google.com
On r7800, when it gives a ping at an interval of 0.5 seconds to the router itself, it's ok, but when I give further, the stairs begin.
With an interval of 1 second, netgear is ok, and from 0.8 seconds and less, the problem begins.
- FURRYe38Mar 31, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router- ChrisPlMar 31, 2023Aspirant
The modem has nothing to do with it, but if you want to know, I have a Huawei OptiXstar EG8010Hv6.
Still the same after following your instructions.
