ChrisPl
Mar 30, 2023Aspirant
R7800 loss ping
Hello I have r7800 with firmware V1.0.2.92 installed. Do other users of this device have the same as me? I am connected via LAN cable. When pinging the world with an interval of 0.5 second...
ChrisPl
Mar 31, 2023Aspirant
Look how my old draytek 2110 router is running.
mtr -i 0.5 -s 1500 google.com
On r7800, when it gives a ping at an interval of 0.5 seconds to the router itself, it's ok, but when I give further, the stairs begin.
With an interval of 1 second, netgear is ok, and from 0.8 seconds and less, the problem begins.
Mar 31, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
- ChrisPlMar 31, 2023Aspirant
The modem has nothing to do with it, but if you want to know, I have a Huawei OptiXstar EG8010Hv6.
Still the same after following your instructions.
- FURRYe38Mar 31, 2023Guru - Experienced User
What are the results on the R7800 if you load up Voxels 3rd party FW and test again.
You can revert back to NG stock FW.
From this side http://www.voxel-firmware.com/Downloads/Voxel/html/r7800.html ?
