RonWh
Apr 21, 2023Follower
R7800 MESH compatible
Is the R7800 compatible to make a mesh system and whit what modles
The R7800 is not a MESH router.
One can add a WiFI Extender like a EX7700 or EX8000 for extended wifi coverage.
To add to that, yes you can add a mesh extender. But if you're needing more than 1 extender, I'd recommend switching to a full mesh system versus using extenders.
RonWh wrote:
Is the R7800 compatible to make a mesh system ....
No, but you might get better advice is you explained what you are trying to achieve.
