BryanSD
Mar 13, 2016Apprentice
R7800 MU-MIMO - Any advantage to disable?
The Nighthawk X4S (R7800) gives you the ability to enable/disable Wireless MU-MIMO. Assuming a person has no MU-MIMO device, is there any advantage to disabling this capability with regards to router...
- Mar 13, 2016
None
NightOwl326
Mar 13, 2016Luminary
None
- BryanSDMar 15, 2016Apprentice
Thanks NightOwl. With no one else diisagreeing with you, I'll take your answer as the answer!
