omoeller
Mar 15, 2019Guide
R7800 NighHawk X4S - 5Ghz Drama
Looks like my 5 Ghz band got screwed after of hassle free weeks. I tried to reset, tried different FW versions and was not successful getting 5Ghz back to work. I finally ended up going down to FW .5...
- Mar 15, 2019
I use .62 firmware but don't use the 5 GHz band much so no problems here. But there are users reporting it still has issues on .62. These issues are also present on .58 and .60 firmware. Your best bet is to stay on .52 and wait for a future update that hopfeully fixes it once and for all
Mar 15, 2019Guru - Experienced User
Several people have been reporting problems with 5ghz on the newest firmware. If you don't have any other issues with the downgraded firmware, I'd wait for a newer version to come out. You could put in a ticket to netgear support to see if there is any beta firmware available to try.
