omoeller
Mar 15, 2019Guide
R7800 NighHawk X4S - 5Ghz Drama
Looks like my 5 Ghz band got screwed after of hassle free weeks. I tried to reset, tried different FW versions and was not successful getting 5Ghz back to work. I finally ended up going down to FW .5...
- Mar 15, 2019
I use .62 firmware but don't use the 5 GHz band much so no problems here. But there are users reporting it still has issues on .62. These issues are also present on .58 and .60 firmware. Your best bet is to stay on .52 and wait for a future update that hopfeully fixes it once and for all
shadowsports
Mar 15, 2019Hero
Search for user microchip8 (check his sig). Whatever FW he is running on his R7800 is likely a safe bet.
- microchip8Mar 15, 2019Master
- omoellerMar 15, 2019Guide
Thanks folks - will stick on .52 for now, BTW faced the same issues with Voxels versions as well - just as FYI
might be hardware related. i don't know. But since it works on .52, there's something going on but I can't say what exactly
