kwahaes
Jul 11, 2021Aspirant
R7800 no internet after power outage
I have been experiencing some issues with my R7800 for a while now. If the power goes out for any duration, my router and cable modem both come back up, but my router never recovers the internet con...
antinode
Jul 11, 2021Guru
> [...] None of this can be done remotely. [...]
It might be possible to do something local automatically, however.
If you had a computer on your LAN which reliably started when power
returned, then it might use a program like Wget to prod the router
repeatedly until communication with the outside world returned. A (very
cheap) Raspberry Pi might serve, for example. But investing in a better
router might be a better use of resources (money and time).
> [...] Seems like Netgear could fix this.
Many things are possible, but, without a formal complaint from a
paid-support customer, I wouldn't hold my breath. (Even with, ...)
OhBeWan
Sep 16, 2021Guide
I have the same issue, except mine cannot be fixed by going into the software. I must physically disconnect the ethernet cable plugged into the WAN port then plug it back in again.
Just now, I was reading to see if there was a fix. Found out there was a new firmware, so I upgraded. After upgrade, I had no internet. So, I unplugged the cable, plugged it in again and magic, I have internet.
Lost power a few days ago. Just for a fraction of a second. Many devices such as clocks didn't even notice it. Router stayed on, but cable modem rebooted. When it came back up, router did not sense that we had internet again. Had to unplug and replug cable.
Problem is: What do I do when I am away from home and I want access to whatever media, camera, data or other useful product that is on my network? Only solution I have is to put the cable modem and router on an UPS box.
PS - I have posted about this issue before. Other users have the same situation. Started after FREE support ended. Perhaps with the same firmware OP mentioned.
- FURRYe38Sep 16, 2021Guru - Experienced User
- OhBeWanSep 16, 2021Guide
Thanks for replying so quickly. My current firmware (just updated this morning) is V1.0.2.84. Re-ran the update assistant and it says NO newer updates are available.
The cable modem is an Arris TM1602.
Thanks.
So if a brown out happens the R7800 doesn't recover the internet automatically after it comes back ON?
Do you have both router and ISP modem on same UPS now?
