Brownk
Oct 27, 2022Aspirant
R7800 Non-Responsive
I am having trouble accessing my R7000 Router.
We experienced a power failure and I turned off our DSL Modem/Router and R7000 Router and disconnected power. When the electricity came back on, ...
Oct 27, 2022Guru - Experienced User
What's seen on the 7000s web page under basic?
Please post a screen capture here however edit out the SSID name and PW before posting.
Are the wifi LEDs on the top of the router ON?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended.
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
- BrownkOct 27, 2022Aspirant
Thanks for the prompt reply FURRYe38.
First, I should note that we actually have a R7800, not a R7000.
The Firmware version was 1.0.2.90.
I have a suspicion as to what happened, but it doesn't explain why the 2.2 and 5 GHz signals were not broadcasting (and still do not).
The problem may have been a bad sequence of events that ultimately left the router with partial/corrupted firmware.
When the AT&T Modem/Router came back online, it misconfigured and yet would still access the internet. Unfortunately, when I factory reset the R7800, it defaulted to automatically update the firmware. The router was configured to not do this, as I prefer to check the firmware manually and if need be, download and upload. I was unaware that new firmware (v1.0.2.92) was posted, recently. So the unit started to update the firmware through the misconfigured AT&T Modem/Router. Unfortunately, it was only after I reset the R7800 and sat down with my tablet, that I received a prompt that something was wrong with the AT&T Modem/Router. By then, the damage was done.
Since the firmware was corrupted, I cannot access the R7800 menu via a browser. That an incomplete firmware update has "bricked" the router. Now it is lost in some incomplete process and will not stop.
This leads me to believe the only hope is to try and upload clean firmware via TFTP and a command line. My concern is that since the router is active the minute it is connected to a WAN port, will this approach work?
Regarding DMZ, this was second approach recommended by AT&T. There was no instructions regarding my specific Modem/Router. Found instructions for another model and assume the approach would basically be the same. Our AT&T Modem Router doesn't do "Bridge Mode" in the purest sense. Because I am not the best versed in Networking, I was hesitant to use this approach. Feared it would expose our Network to vulnerabilities beyond my comprehension or visibility. I just started using this approach with the AT&T Modem/Router, recently. Prior, I was using an old Netgear Modem/Router in Bridge Mode, but that model hadn't seen a firmware update in years (DM111PSPv2). I figured it as alright, because it was just acting as a Modem and the R7800 managed the rest.
Even connecting the R7800 to my old old Modem/Router in Bridge Mode doesn't help. Thought being that there should be no conflict that might be part of essentially running two two routers. I cannot access the Internet nor access the R7800 menu. As soon as I connect to a WAN port, the unit starts sending/receiving packets at about 1 per second. The Router will not stop communicating, which prevents accessing the menu. That or that the firmware is too corrupted to function, properly.
Once again, thanks for your assistance in the matter. If I can get the R7800 to work again, I will consider using the ISP provided equipment and the R7800 in DMZ. Not sure if I should just stick with the less complex approach of using the old Netgear Modem/Router in Bridge Mode and the R7800, combination?
- michaelkenwardOct 28, 2022Guru - Experienced User
This can happen, but rarely. When it does, people usually manage to manually update the firmware.
If the power LED is as expected, solid white, that would be a first move.
When the AT&T Modem/Router came back online, it misconfigured and yet would still access the internet. Unfortunately, when I factory reset the R7800, it defaulted to automatically update the firmware. ?You can prevent that from happening by resetting the R7800 and keeping it of line as it goes through its wizardry. (You should also be able to stop that from happening in the first place.)
You can then manually update the firmware and set it up to prevent automated updates. (I also disable password recovery, which has its own "closed loop" gotcha.)
There are various other tricks, some of which I had to get into when testing the R7800 hardware for another purpose. But the first move should be to try the simplest and safest,
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- BrownkOct 28, 2022Aspirant
I cannot get the unit to do a complete factory reset. It clearly is partially resetting, because the unit has defaulted to the IP of 192.168.1.1, but the 2.2 And 5 GHz status lights remain dim even though the Wi-Fi light is on. A browser will not access the units menu. It immediately errors with cannot find the server or that the unit is busy. Whatever WAN port I use exhibits activity, immediately, without even opening a browser. Once I open a browser and try to access the units menu, to activity gets worse. Cannot get the unit to stop communicating; like it is stuck in a transmission loop, or something. That is why I felt the only hope was to try and access the unit via a command line (sans using a browser, altogether).
Once again for clarification. Unit will not do a complete factory reset and a browser will not access the units menu, because the unit is busy. Busy doing what? I have no idea. At least 1 packet a second and will not cease communicating.
I will try another “hard” reset. That being hold the reset for 30 seconds, unplug unit while still pressing reset for 30 seconds and while still continuing to hold the reset - reattach the
for power and wait for 30 seconds.
