Brownk
Oct 27, 2022Aspirant
R7800 Non-Responsive
 I am having trouble accessing my R7000 Router.
 We experienced a power failure and I turned off our DSL Modem/Router and R7000 Router and disconnected power.  When the electricity came back on, ...
Brownk
Oct 28, 2022Aspirant
Michael,
If you are referring to the ISP AT&T Modem/Router, it is a Netgear 7550.
Normally, I ran the old Netgear Modem/Router (DM111PSPv2) in Bridge Mode and had the R7800 handle everything.
We have had serious Internet issue’s over the years. We live in a rural environment and on DSL with a maximum of 6 Mbps.
The last Technician suggested running the R7800 behind the ISP supplied Modem. Normally, we would run either just the ISP supplied device or the prior mentioned Netgear/Netgear setup.
We had been experiencing constant disconnects, so I thought I would try a different configuration. I regret doing so, now.
Why the R7800 refuses to do a complete factory reset is confusing.
Throughout or issue’s, I have had a vehicle on our property line that seems to be running a hotspot. I have watched for this vehicle to move and it has not.
I have tried working with the R7800 connected to just a computer, but if cannot get the thing to factory reset and access it’s menu, it seems I am dead in the water.
I have become suspect that somebody has spoofed the router.
I try to eliminate all interference. Turn off our two tablets, unplug our computer, unplug our smart tv, disconnect and unplug our ISP equipment, but I cannot escape the Wi-Fi from our Neighbor’s. We live in the middle of five acres and the amount of Wi-Fi in the area is unbelievable.
Only thing I know to do is try TFTP via a command line. Hesitant, though.
- michaelkenwardOct 28, 2022Guru - Experienced User
One of those custom jobs that you can't buy out in the consumer world.
Now pretty ancient. Can it really date back to 2008?
Is this why it is not possible to login to the #browser graphical user interface (GUI)?
- BrownkOct 28, 2022Aspirant
I generally have not been using the ISP equipment with the R7800, since the trouble began, because it will not work. I have been using a computer that is not connected to the Internet.
Don’t get me started on AT&T. That would lead to a very long tirade. Unfortunately, they as usual, are the cheapest internet in our area. They are the only wired, also.
We have been on the same account for sixteen years. Seems DSL went legacy almost a decade ago. Other than AT&T wired, it is all wireless or satellite.
I complained to AT&T that our Neighbors were spoofing our internet. Finally caught a neighbor spoofing via capturing their router using our SSID. Even tough I had a screen print, they would do nothing without something from law enforcement.
Our original ISP Modem died (Siemens Soundstream?). Since we were on legacy status, we bought the Netgear DM111PSPv2 as a replacement. The AT&T unit was expensive and we our on legacy status!
In the years past, still having problems, I contacted AT&T support. I figured our Network was still being spoofed. I asked whether we showed as being connected to the AT&T Server and we were, but it showed no activity even though I was on the internet. That is why I have the AT&T ISP Netgear 7550. The Support Tech was alarmed and sent me a free unit. Something they had refused to do in the past.
From what I can tell, AT&T buys discontinued equipment and installs their own firmware on the unit.
We always used non-wireless via Ethernet. In 2017, my Wife got an iPad, so we needed a Wi-Fi Router. We chose an AirPort Extreme hooked up to the Netgear DM111PSPv2. It was being spoofed (noted above). Started using the ISP supplied Netgear 7550, but it had spotty performance, so we bought the Netgear R7800 and went back to the DM111PSPv2. Started experiencing disconnects, recently, and decided to try the R7800 behind the ISP Netgear 7550. Now, as per this thread, the R7800 is not working.
Years ago, all DSL Modem based units disappeared in unity. Conspiracy?
Indeed. But not a conspiracy by Netgear.
Anyone familiar with cable internet knows that ISPs insist on having control over modems. They are the only ones that can update firmware. Neither Netgear nor users have any control.
Talking to the network operator behind by my Internet service, I gather that they have told ISPs to provide customers with modem/router combinations. As a result, there are very few modem only options in the DSL market.
By good luck I got a Netgear DM200 just before they went off the shelves. When I wanted a second DM200, for my other line, I managed to get one of those "opened box" offerings.
These things come up from time to time at reasonable prices on the usual on-line second-hand store.
I use an R7800 with one of these.
The usual way to deal with that is to use a strong password and then to set the router to block all unknown devices from connecting to the wifi.
You can also hide the SSID, but that will not keep out a truly determined, and technically competent, intruder.
