Weegi21
Dec 11, 2022Follower
R7800 not working with BT TV Box Pro
Hi, We have replaced the BT smart hub 2 with our nighthawk X4S R7800 router due to poor wifi connections from the BT smart hub throughout the house. I completed the smart set up to complete the P...
michaelkenward
Dec 12, 2022Guru - Experienced User
What are you using to connect to the Internet? The R7800 is a router, it usually sits behind a modem.
The BT smart hub 2 is a modem/router.
What sort of Internet does BT supply to you? DSL and fibre are the most common.
I have a BT TV Box Pro working happily behind an R7000P. I haven't tried it on the R7800, but they are essentially the same network technology. In my case the R7000P sits between a DM200 modem and the BT box.
