youdue
Apr 16, 2019Tutor
R7800 parental control with Nighthawk app
I bought the R7800 because of the parental control. Now that Netgear Genie is not supported anymore and Disney Circle does not support the R7800, the parental control does not work anymore. Any chanc...
- Apr 17, 2019
Use Desktop Genie app.
DexterJB
Apr 17, 2019NETGEAR Moderator
Hi youdue,
Welcome to the community!
You can always use the desktop (PC and Mac) version of the Genie app and manage your LPC settings from there. You download it from here.
Dexter
- youdueApr 18, 2019Tutor
Hi Dexter,
Thanks for your answer, but the Genie app is not available anymore. Your link sends to the Disney Circle which does not support my router.
I should have read it all. At the bottom I found the link to the desktop app.
- becharskiApr 25, 2019InitiateIt is way inconvenient to use the desktop app. It now takes minutes instead of seconds on the phone. Are the going to bring that functionality back to the phone app? I've gotten several people to buy this router because of that functionality alone
