wizzkid22
Oct 27, 2019Aspirant
R7800 QoS on device priority issues on v1.0.2.63
R7800 QoS on device priority issue on v1.0.2.63 Can someone help on this issue please , it may also help others. My issues are when QoS is enabled in the quality of service options and th...
- Oct 31, 2019
you could try to roll back a firmware version and see if that resolves the issue that would let us know if it is a bug in the current firmware.
DarrenM
DarrenM
Oct 31, 2019Sr. NETGEAR Moderator
Have you tried another web browser?
DarrenM
- wizzkid22Oct 31, 2019Aspirantthankyou for the reply Darren, I had tried Firefox, opera mini, explorer and duckduck go . the nighthawk x4s is in router mode with virgin hub3 in modem mode. with different browsers used , it changes priority then apply but soon goes back to low. using v1.0.2.63 beta. had factory reset when it was updated for the patch and upnp turned off.
- wizzkid22Oct 31, 2019Aspirantthe device is still under warranty for the router till 2021 and using custom firmware would void it , if that's still correct.
- DarrenMOct 31, 2019Sr. NETGEAR Moderator
DarrenM
