wizzkid22
Oct 27, 2019Aspirant
R7800 QoS on device priority issues on v1.0.2.63
R7800 QoS on device priority issue on v1.0.2.63 Can someone help on this issue please , it may also help others. My issues are when QoS is enabled in the quality of service options and th...
- Oct 31, 2019
you could try to roll back a firmware version and see if that resolves the issue that would let us know if it is a bug in the current firmware.
DarrenM
wizzkid22
Oct 31, 2019Aspirant
the device is still under warranty for the router till 2021 and using custom firmware would void it , if that's still correct.
DarrenM
Oct 31, 2019Sr. NETGEAR Moderator
DarrenM
- wizzkid22Oct 31, 2019Aspirantthankyou DarrenM I will check on Netgear download site and role back and get back to you DarrenM.
- myerswOct 31, 2019Master
Imagine that. A bug in new firmware. What a surprise.:smileyhappy:
For at least a year, based on experience, Netgear QA is non existent. Test for bug fixes? Don't make me laugh.
- wizzkid22Oct 31, 2019Aspirantjust rolled back to 1.0.2.62 and guess what? using duck duck go and the device priority is working, thankyou DarrenM and myersw it appears that the 1.0.2.63 beta version has a bug , selected my devices that needed priority changes for gaming and it stays on what is picked, happy it's back and no more laggy devices.
Glad your are up and working again. With the shoddy firmware I would turn off auto update if not already off and be very carefull with doing any firmware updates with expecting to have to drop back. ;(
