Hulkster
Oct 06, 2017Aspirant
R7800 Readyshare not enough space
Hello, I have a R7800 router with a 3 tb WD harddisk attached to it! And all of a sudden I notice that I can't copy big files anymore to the disk. I get the weird message "There is not enough space o...
- Nov 17, 2017
Hulkster wrote:No solution yet! Also I found out that deleting a big file from the harddisk is a problem and it gives an error message! On Windows 7 it gives this error message on Server 2016 it doesn't and it looks like it deletes it but then when you do F5 or go back and in the directory again it is still there!
I am getting more and more sorry for buying Netgear again after all this time!
i use voxels firmware. it is improved build of stock firmware. works like a charm. he corrected many ng's problems and with readyshare [samba] and other bugs too. works much faster and hw accelerated nat is working too.
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-39sf.41945/
avtella
Oct 06, 2017Prodigy
This happens on the latest R9000 beta as well. Reason is Netgear is trying to use the latest Samba version as Microsoft is removing SMBv1 support so most networking companies are scrambling to Samba 3.6 while Netgear is trying to use 4.6 I believe. They also need to strip the Samba stuff down so it’s small enough to fit in the router firmware and it seems they may have hit a snag somewhere.
Hulkster
Oct 07, 2017Aspirant
Thank you so much for letting me know! Very usefull information (Kudo)! I knew something must have happened because this is not normal behaveour.
I hope they will fix this soon! Keep me inform if you hear they fixed it please!
