Hulkster
Oct 06, 2017Aspirant
R7800 Readyshare not enough space
Hello, I have a R7800 router with a 3 tb WD harddisk attached to it! And all of a sudden I notice that I can't copy big files anymore to the disk. I get the weird message "There is not enough space o...
- Nov 17, 2017
Hulkster wrote:No solution yet! Also I found out that deleting a big file from the harddisk is a problem and it gives an error message! On Windows 7 it gives this error message on Server 2016 it doesn't and it looks like it deletes it but then when you do F5 or go back and in the directory again it is still there!
I am getting more and more sorry for buying Netgear again after all this time!
i use voxels firmware. it is improved build of stock firmware. works like a charm. he corrected many ng's problems and with readyshare [samba] and other bugs too. works much faster and hw accelerated nat is working too.
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-39sf.41945/
ImryL
Oct 15, 2017Aspirant
Having the same issue, cannot copy files ober 2GB to the drive with the latest firmware.
Don't Netgear QA before releasing? This is such a trivial bug to catch.
Rolled back to 10.0.2.32
rbird2
Oct 15, 2017Luminary
I could be wrong but my guess is that Netgear (as with other companies) is sending it's software development overseas. Once this happens, they loose direct control of the quality and timely bug fixes. Add the language barrier, getting bug information second hand, etc., and it’s a recipe for disaster. Unfortunately, this is the world we now have to live with...
