Hulkster
Oct 06, 2017Aspirant
R7800 Readyshare not enough space
Hello, I have a R7800 router with a 3 tb WD harddisk attached to it! And all of a sudden I notice that I can't copy big files anymore to the disk. I get the weird message "There is not enough space o...
- Nov 17, 2017
Hulkster wrote:No solution yet! Also I found out that deleting a big file from the harddisk is a problem and it gives an error message! On Windows 7 it gives this error message on Server 2016 it doesn't and it looks like it deletes it but then when you do F5 or go back and in the directory again it is still there!
I am getting more and more sorry for buying Netgear again after all this time!
i use voxels firmware. it is improved build of stock firmware. works like a charm. he corrected many ng's problems and with readyshare [samba] and other bugs too. works much faster and hw accelerated nat is working too.
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-39sf.41945/
klwong36
Oct 10, 2017Tutor
It's definitely a problem with this firmware version. I saw elsewhere that somebody used the wrong size variable, and ReadyShare just can't handle files larger than 2 GB in size.
Until this bug gets fixed, I have reverted to 1.0.2.32.
This is a shame, since 1.0.2.36 fixes a security vulnerability. Unfortunately, I really need access to my large files, so I don't have a choice but to revert, and wait for a new (fixed) firmware.
DZ-Br
Oct 18, 2017Aspirant
Thanks a lot. Going back to the Firmware 1.0.2.32 fixed the problem. Hope Netgear will fix the problem with a new version...
