FlashFlood
Sep 25, 2024Aspirant
R7800 ReadyShare rejects connections to drives secured by admin password. Must update admin password
R7800 ReadyShare rejects connections from all devices to USB drives (2) secured by admin password. Must update admin password to itself to restore connections. This occurs periodically. I have n...
michaelkenward
Sep 25, 2024Guru - Experienced User
FlashFlood wrote:
Firmware version V1.0.3.92
1.0.2.92?
Where do you see this? Windows?
The R7800 hasn't caused me any problems on that front. But mine is now in AP mode, simply to give me ReadyShare.
Just another user with time on their hands.
FlashFlood
Connections to the drives fail on MacOS, IOS, Android and Windows platforms. I connect to the router, update the admin password to the same value and I am subsequently able to connect to the drives from all devices.
I do not have to update any configurations other than the admin password to restore connectivity. I recall reading some time ago that it was necessary to update the admin password after adding a new drive and securing it with the admin password. It seems like ReadyShare configuration reverts to this initial state periodically. When it first happened, I updated with a new password and changed the connection credentials on all my devices until I realized I can just update the password to itself to resolve the issue. Still very annoying when it happens.
- michaelkenwardSep 25, 2024Guru - Experienced User
Do you really need to password protect the USB drives? I don't.
- FlashFloodOct 03, 2024Aspirant
Appreciate the response. I will consider your suggestion..
Since support for my router has expired, I posted here in to get confirmation that this behavior was a bug and was being addressed.
- michaelkenwardOct 03, 2024Guru - Experienced User
Could be no on both counts.
As I said, I don't see this behaviour, and it hasn't been a constant complaint. So if it is a bug it is limited in who it hits.
And it is an old router – several generations behind modern technology – so don't expect to see bug fixes, especially rare ones. It may get the occasional security update, but that's the extent of the support.
