Cozd
Jan 28, 2021Tutor
r7800 recently started giving 403 error for google/search and most netgear/support sites
i get 403 errors when trying to use google/search and when trying to netgear support sites. I do not get these errors when going straight through the modem or when I use mobile data on my phone. It i...
- Jan 29, 2021
do you have a screen snip of the internet setup page?
Have you tried a factory reset and reinstall?
Jan 28, 2021Guru - Experienced User
What modem/gateway is it connected to?
What firmware is on the router?
Is this a new issue or has it been going on for a while
Cozd
Jan 28, 2021Tutor
motorola sb6121 modem - Problem does not exist when connected straight to modem
Router Firmware Version V1.0.2.80
Noticed this a couple of days ago but it was using wifi on my phone and didnt really chase it. Just started chasing it today.
- plemansJan 28, 2021Guru - Experienced User
try using a different dns provider.
Try googles at 8.8.8.8 or 8.8.4.4
or cloudfare at 1.1.1.1
- CozdJan 28, 2021Tutor
Thanks for the answer. i hadnt tried that. It is not working so far but i might be missing something
- CozdJan 29, 2021TutorDoesn't seem to make a difference what dns I am using. Not sure what is going on.
- plemansJan 29, 2021Guru - Experienced User
