skumad
Jun 26, 2021Aspirant
R7800 replacement antennas
Hello, So I found a R7800 router in good condition at a great price, but the antennas were missing. I had been keeping my eye on Ebay for some antennas, but couldn't find any genuine ones. Would Asus ...
skumad
Jun 27, 2021Aspirant
Awesome.. yeah they are detachable rp-sma. Do you have any idea about the gain level of the original antennas? Would aftermarket 9dbi anetnnas work with this? I can't seem to find any specs about the original antennas online
Jun 28, 2021Guru - Experienced User
they should work fine with it. Most people don't see a whole lot of difference if they do use more sensitive antenna's but some claim they do.
I've used replacement antenna's before without any issues (kids think they're great toys).
