Thisjustin5
Nov 12, 2020Aspirant
R7800 restarts
Nitehawk x4s R7800 frequently restarts. It will lose connection wired and wireless, power light goes amber, and it will boot up and connect without me doing a thing. I've read thru old, closed post....
JayboH
Nov 13, 2020Apprentice
Did this start after upgrading to .76?
- Thisjustin5Nov 13, 2020AspirantIt's been happening for months and becoming more frequent. I'm not sure if it started w/ the .76 firmware I thought the modem/service was the problem only became aware of the router issue in the last month or so.
I rolled back to .46 firmware which was recommended and it was fine for a week or so then same thing.- canepaNov 25, 2020Tutor
In my case reverting to version 1.0.2.68 solved the problem.
You can read more here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Netgear-R7800-Firmware-1-0-2-76/m-p/2007947
- JayboHNov 25, 2020Apprentice
Ok so awhile back what I did was factory reset by holding a toothpick in the reset button for half a minute just to be extra sure. When it asks you to update to the latest firmware (.76) I said yes.
Now here's the kicker: do NOT restore your saved settings. Put them in manually one by one.
I haven't had any issues at all now. You can see my past posts that .76 was giving me lots of problems until I did this (I discussed it in several threads, not just this one.)
