faab64
Jul 20, 2024Aspirant
R7800 router showing RED on power and can no longer connect to it via WiFi or cable
Hi, My wife came back after working in US for some time (I live in France) and brought back her R7800 with her. Since it is a much better router than the one that comes with our internet provid...
- Jul 21, 2024
Thanks, I know, I just installed DD-WRT on it and going to go from there.
Thanks to you, it is no longer bricked and I can communicate with it.
michaelkenward
Jul 21, 2024Guru - Experienced User
faab64 wrote:
I accepted it and it went on for a while and I left it to walk the dog and came back to see the power LED light showing RED, no Wifi is visible, tried to connect with calble and it keep initializing connection before dropping it, tried factory reset, I see that it turns off after a few seconds and then goes back to the same mode.
A red power LED is a sign of broken firmware. Perhaps something happened while you were out walking the dog.
There is more severe, recovery reset, that you could try:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If that fails, you are into TFTP country.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This isn't the easiest operation, so if you are forced to use it, you could try a web search to find videos that guide you through the process.
Different router same process.
- faab64Jul 21, 2024Aspirant
Thank you, I tried everything and I believe it is time to use TfTP on it. I have never done it and hopefully it will work!
- michaelkenwardJul 21, 2024Guru - Experienced User
If at first you don't succeed, try and try again.
It can take a few attempts. Timing is important.
Thanks for your help, hold the reset in for a long time before the power LED started to blink white, then managed to use TfTP via port 4, the other 3 did't work.
It is now updated with the latest FW, now I need to download new FW to be able to use it with NordVPN.
Hopefully it will not break like last time.
