DasVillain
Jan 30, 2021Aspirant
r7800 router wifi horrible
Hello Netgear community, I went against my own suggestions and purchased a Netgear router (r7800 x4s ac2600). At first (for a few moths) it worked great; I was getting good throughput on both 2.4ghz...
Jan 31, 2021Guru - Experienced User
When you downgraded firmware, did you do a factory reset and clean install (not from backup)?
When you cleain install leave access control, qos, parental controls, and traffic monitoring off.
also, how are you checking speeds? (built in app, what device, etc)
