paulanderegg
Nov 13, 2021Tutor
R7800 share attached USB drive like a NAS?
I need to access a lot of Final Cut Pro libraries and don't want to be tethered to my HDD device. My Macbook has 3x3 MiMo so I was hpoing to use the R7800 in the same room to serve me access to the h...
michaelkenward
Nov 14, 2021Guru - Experienced User
paulanderegg wrote:
I can plug things into the USB ports and the log states USB device attached, but the Readyshare screen never shows anything and all KB tutorials for typing SMB and such simply do not work.
Have you setup ReadySHARE on the router?
I have no idea what your screen grab is from. Something Mac?
Is everything in your local network or are you hoping to tunnel in over the Internet? I the latter, have you set up ReadyCLOUD?
One thing that hit Windows users was the SMB setting in Windows.
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
I have no idea if this hits Macs, but it may give you some pointers.
