perseid
Nov 29, 2019Aspirant
R7800 ShieldsUP fails Stealth mode/Replies Ping
Hi all, I performed the ShieldsUP! test on all ports and all ports come green (Stealth), however it fails the test because of the following: "Ping Reply: RECEIVED (FAILED) — Your system REPLIED ...
- Dec 03, 2019
> [...] the ISP has placed another router between mine and the internet.
> [...]_Someone_ has. It could be your ISP; it could be your building
management. I would expect an address like "192.168.0.x" to come from
some (small-scale) local router, not from an ISP.> [...] First time I see this.
It may not be the last. Especially if you don't deal directly with
an ISP. (Or if your ISP uses CGN.)
> [...] my Nighthawk was set in AP Mode. [...]You could go back to that kid of arrangement, but there are
disadvantages that way, too. For example, your devices would then be on
the same LAN subnet as those of any other user who also uses that same
invisible router which is somewhere beyond your wall, Potentially,
everyone in the building.
perseid
Dec 02, 2019Aspirant
Here is a screenshot
antinode
Dec 02, 2019Guru
Ok. As I read that, the router's LAN IP address is the default,
"192.168.1.1", and its WAN/Internet IP address is "192.168.0.115", which
is a (another) private address, presumably assigned by the (other)
router which is somewhere beyond your wall.
Presumably, what you got from whatismyipaddress.com was _not_
"192.168.0.115". The implications of that difference have been covered
already.
