blunderdome
Jun 02, 2017Aspirant
R7800 Showing Multiple DHCP Lease Events at Renewal
Since picking up a new R7800 a couple of weeks ago I've noticed something odd in the event logs. It seems that when devices check in for DHCP renewal the logs will sometimes show the same device bei...
- Jun 05, 2017
Yeah, I picked up a second one over the weekend to try out - it did the same thing almost immediately so I'm not going to stress it. Gave the devices that were finicky static IPs and called it a day.
GearNetRouter
Jun 02, 2017Virtuoso
Remove the specific device and try it on another router?
blunderdome
Like I said, it doesn't happen on other routers and it's not happening to one specific device.
- doraemonJun 05, 2017Prodigy
Perhaps, use a different fw version?
If it persists, replace the unit.
- blunderdomeJun 05, 2017Aspirant
- mondenathJun 06, 2017Prodigy
You can also try sending the log not on full but say 1hours schedule. It will not be full log. But you may need to add it to labels like in gmail to avoid 24mails a day and more to come in a month. Say 750+ a month
