KTO2
Jan 06, 2022Tutor
R7800: SMB Works, FTP Doesn't
If I use a flash drive formatted NTFS both SMB and FTP work fine and do everything they should. If I use an SSD formatted NTFS SMB works fine and does everything it should but trying to connect w...
- Jan 10, 2022
An update on this in case it helps someone else as I was still getting problems.
The culprit was the SSD enclosure. I tried 2 other flash drives and four other HDD/SSD's and they all worked fine with FTP so I swopped the original SSD in to one of the other enclosures and it worked immediately and has continued to do so since (I even swopped things back to double check if the problem would reoccur and it did).
Why it wouldn't work with FTP but would with SMB is beyond me as is why FTP would work with the R7000 but not the R7800.
Jan 06, 2022Guru - Experienced User
This should be posted in the Nighthawk Router forum area (not ReadyNAS). I am moving it for you.
KTO2 wrote:
I am changing no settings and doing nothing different with Filezilla/FTP between the flash drive and SSD and have swopped the flash drive and SSD back and forth more than once to double check I am doing nothing different.
Are you wanting to use FTP over the internet, or are just on your home network?
