KTO2
Jan 06, 2022Tutor
R7800: SMB Works, FTP Doesn't
If I use a flash drive formatted NTFS both SMB and FTP work fine and do everything they should. If I use an SSD formatted NTFS SMB works fine and does everything it should but trying to connect w...
- Jan 10, 2022
An update on this in case it helps someone else as I was still getting problems.
The culprit was the SSD enclosure. I tried 2 other flash drives and four other HDD/SSD's and they all worked fine with FTP so I swopped the original SSD in to one of the other enclosures and it worked immediately and has continued to do so since (I even swopped things back to double check if the problem would reoccur and it did).
Why it wouldn't work with FTP but would with SMB is beyond me as is why FTP would work with the R7000 but not the R7800.
schumaku
Jan 06, 2022Guru - Experienced User
If I use an SSD formatted NTFS SMB works fine and does everything it should but trying to connect with FTP I get connection refused by server.
This does not make any sense to me - because of ftp does connect to the ftp "root", represented as /shares - regardless which folder or path you request the access. Something must be different on the two FileZille sites.
Trying to use the ftp over the Access Method LAN or e.g. for the second one FTP(Internet)? In the second case, well possible you hit an FTP ALG on your router, or the ftp server isn't exposed to the Internet at all for many different reasons (lack of port forwarding, double NAT, CGN (carrier grade NAT).
- microchip8Jan 06, 2022Master
I strongly discourage the use of FTP for anything Internet-exposed. It's fine on your LAN but on the Internet it's easy hackable since it provides no security and anyone can brute-force it. (yes, ftps is secure but NETGEAR doesn't support it)
