oldfart825
Aug 25, 2021Guide
R7800 Speed degrades over a day
Hello everyone. Here's my issue: I bought my R7800 about a year ago, when I saw that they were running fiber in our neighborhood. At that time we had 6Mb DSL and typically got 5Mb at best. As my old ...
michaelkenward
Sep 11, 2021Guru - Experienced User
oldfart825 wrote:
My fiber connection is through the local fiber provider - MidSouth Fiber. The modem is a Calix Gigapoint 803G and is just a modem, so I can't do a connect through the modem alone.
Being "modem only" does not prevent you from connecting a PC to the device and testing the speed and the connection. You are simply limited to one wired device. That test would tell you what you are getting through the service.
You said earlier:
Run speedtest. 670Mb down, 45Mb up.
How did you run a speedtest? Wifi tests tell you nothing, because they are client dependent, and even wired tests are unreliable because some test servers are better than others. I usually run a handful of tests on different servers.
You also said:
I know routers need to be rebooted occasionally because the memory tends to "load up" with crap,
I have an R7800 that gets rebooting once in a blue moon, usually when there is a power cut. So that sounds like a myth to me.
A key point is that you have used this R7800 with an earlier Internet account.
It is highly advised to reset the router when changing accounts, so that it forgets any settings inherited from the previous account.
oldfart825 wrote:
I've tried everything except a 30/30/30 reboot and as soon as I get a chance
I bask because I wondered where you got the 30/30/30 reset idea from. (Reset and reboot are completely different processes.) It is not the usual way to clear settings when you move accounts.
A conventional reset is usually adequate. If you have already done that, then I doubt if the recovery reset – the 30/30/30 thing – would get you much further. If you haven't reset the thing since you moved from DSL to fibre, that is the obvious first move.
When you do have things up and running, be sure to disable anything that puts a load on the router's processor, such as QoS (a pointless exercise with fast Internet) and traffic metering.
If you still see the same symptoms, which don't look good, then you might need to get into RMA territory.
oldfart825
Sep 11, 2021Guide
I use the speed test at www.speedtest.net. I test with several servers located all over the US. We have 3 PC's in the house, and I have conducted the tests with all of them. I conduct the speed test with only one device - whichever PC I am testing from - connected directly to the ethernet ports on the router. Normally they would be connected to my gigabit network switch. Nothing connected to wifi, nothing. All PC's are hardwired over CAT6 cable. I get the same results regardless of PC, so I have eliminated problems with any of them.
I didn't think I could just plug into the WAN port on the modem, so I'm going to try that and see what happens.
Many people here in this forum have mentioned routers needed to be rebooted periodically and while that works - for a few minutes - the speed problem reoccurs pretty quickly. I don't use QoS or speed metering, no parental controls. The only thing I change from factory settings is the password (I would change the username if it would let me), the gateway (router) address, and the wifi settings.
All of that said, I'll try plugging direct into the modem and see what happens and then go from there. I'll report here what happens. Thanks for your input!
- michaelkenwardSep 12, 2021Guru - Experienced User
Perhaps you could point us to some of those messages. It would be interesting to see why they suggest that.
Anecdotal evidence is never a good guide. A reboot is not recommended practice. It is something that people do when trying to fix problems.
Most people would leave the "gateway (router) address", whatever that is, alone. Why would they want to change it?
Things you may need to change are the ISP specific settings. A common one is "MTU Size". Your ISP should be able to tell you the optimum settings for its service.
- michaelkenwardSep 13, 2021Guru - Experienced User
Netgear has just released new firmware for the R7800.
Try that.
- oldfart825Sep 13, 2021Guide
Ok, I'll check that out. That being said, what is the best procedure for upgrading? Normally I just upgrade through the web interface and reboot the router. Do I really need to do anything else?
