CSProf1
Oct 01, 2020Aspirant
R7800 Speed Issue
Looking for some help/advice. I have an R7800 that I've had for a couple of years (great router, been very happy with it). I just upgraded my cable Internet service to a 400MB service. I'm consist...
- Oct 02, 2020
Some thoughts:
When you are changing, configuring, testing, etc. dismount/disconnect your USB drive and leave it off until you sort out your problems.
Do not restore a configuration file that was created with a different version of firmware.
Install the Voxell firmware for the X4S. https://www.voxel-firmware.com/Downloads/Voxel/html/index.html
Oct 02, 2020Guru - Experienced User
Prior to trying the reset what you can do is disable access control, traffic monitoring, qos, and parental controls. The reboot the router and test it.
If that doesn't work, then I'd try the reset.
