CSProf1
Oct 01, 2020Aspirant
R7800 Speed Issue
Looking for some help/advice. I have an R7800 that I've had for a couple of years (great router, been very happy with it). I just upgraded my cable Internet service to a 400MB service. I'm consist...
- Oct 02, 2020
Some thoughts:
When you are changing, configuring, testing, etc. dismount/disconnect your USB drive and leave it off until you sort out your problems.
Do not restore a configuration file that was created with a different version of firmware.
Install the Voxell firmware for the X4S. https://www.voxel-firmware.com/Downloads/Voxel/html/index.html
Oct 02, 2020Guru - Experienced User
Prior to trying the reset what you can do is disable access control, traffic monitoring, qos, and parental controls. The reboot the router and test it.
If that doesn't work, then I'd try the reset.
CSProf1
Oct 02, 2020Aspirant
Thanks for the suggestions. Access control, traffic monitoring, qos and parental controls are all disabled. I rolled back the firmware version to 1.0.2.68, then did a restore configuration, no change. Then did a wipe and a complete manual rebuild, no change (actually that's not true, things got worse). So wiped and restored from my configuration save. Got speed back up to mid-200s but still no where near what I see at the modem (~500down/30up). I'm starting to fear this just isn't going to work. If not then I'll be looking for new router because I'm getting tired of fighting this battle. Shame too, I always liked this router.
Absoflutely open to other suggestions. To date I've:
1) physically moved the router right next to the modem and used different Cat6e cables to make sure it's not a cabling issue (no change)
2) disconnected all devices except my desktop computer (turned off wireless also) so that my computer was the only one using the connection (no change)
3) did a soft reset using the OS on the router, then restored the configuration from a save (no change)
4) did a hard reset with the reset button on the back of the router, then restored the configuration (no change)
5) physically moved the router back to its usual location and plugged everything back in (network cables and usb drive) (no change)
6) did a soft reset then rebuilt the configuration manually from scratch (things got much worse)
7) restored the configuration from a save when #6 made things worse (that's puzzling) (back to original ~200s)
8) upgraded firmware to 1.0.2.74, rebooted then restored configuration from save (finally, some improvement)
With the last change (#8) I'm now seeing speeds in the mid to upper 300s (and an occasional 400+). For now I'm gonna stop. Not going to call it solved, so if anyone else has any ideas, I'm certainly open to suggestions.
Thanks all, really appreciate the suggestions!!
- plemansOct 02, 2020Guru - Experienced User
What cable modem is it?
- CSProf1Oct 02, 2020Aspirant
It's a brand new Hitron Docsis 3.1. Cable company just came out yesterday and installed it because the previous modem wouldn't get my speed up to the 400+ service I had upgraded to.
- KitsapOct 02, 2020Master
Some thoughts:
