Killhippie
Aug 01, 2016Prodigy
R7800 Streamboost updates are from March
I have just noticed the R7800 Streamboost updates are from the 2nd March 2016, thats just shy of 5 months old. I thought these updates are meant to be at the least updated quaterly, and are to go on ...
- Aug 06, 2016Its been updated to June now so all is partially well, its just that Netgears implementation of it is so very buggy.
Killhippie
Aug 06, 2016Prodigy
JamesGL
Aug 11, 2016NETGEAR Employee Retired
Hi Killhippie,
Thank you for the feedback.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
