juanpablo2
Sep 11, 2020Aspirant
R7800 update from nighthawk app
My router has updated to version 1.0.2.74 from the app, but after the update the app doesnt detect my router for administration, then I tried too enter the administration page and nothing, I make a factory reset and still nothing
I also tried upload my firmware (R7800-V1.0.2.68) and never starts the transfer
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Apps can't do updates on their own. Your firmware was most likely set to auto-update which you should really disable due to the poor state of NG firmware. Try the TFTP method a few times and report back
- microchip8Master
- juanpablo2Aspirant
Thank you, I already tried to flash via tftp but nothing, with this guide I was able to upload my firmware via tftp
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
PS. The firmware that works is the R7800-V1.0.2.68.img, when i flashed with R7800-V1.0.2.74.img doesn't work
