sncpa
Jan 23, 2022Guide
R7800 Updated to 1.0.2.90, now wants to install V1.0.0.423
I checked on my router updates and an update was suggested: V1.0.2.84(~) to V1.0.2.90. Using the firmware assistant, it reported an MD5 Checksum error and failed to install. Per other discussions on ...
Andydie
Mar 05, 2022Aspirant
I also performed the factory reset and always I use a wired PC but always the same issue even now.
Now I have also found another issue, the router no longer allows changing the language, trying to change the language the GUI always returns to English.
But is it not possible to download this type of update to do it manually?
With manual update I was able to update to firmware V1.0.2.90 which otherwise automatically returned the same issue "MD5 verify error"
Regards
Mar 05, 2022Guru - Experienced User
Ya, guess not. Hopefully NG will fix it. I've pass this back to NG.
