sncpa
Jan 23, 2022Guide
R7800 Updated to 1.0.2.90, now wants to install V1.0.0.423
I checked on my router updates and an update was suggested: V1.0.2.84(~) to V1.0.2.90. Using the firmware assistant, it reported an MD5 Checksum error and failed to install. Per other discussions on ...
Dirtnap
Mar 14, 2022Aspirant
I'm having the same issue. Seems to be a bad firmware update. Hopefully NG fixes this soon. Factory resetting this is a bad answer.
DexterJB
Mar 14, 2022NETGEAR Moderator
Hi all, thank you for reporting this. This is currently being worked on by the team. We will provide an update as soon as it is available.
Dexter
NETGEAR Team
- KevinChenMay 15, 2022Aspirant
Hello, 2 months passed, has this GUI issue solved?
I have a similar experience about 5 years ago, at that time, NETGEAR told me my ISP blocked the downloading (however, updating firmware was ok)
- FURRYe38May 15, 2022Guru - Experienced User
Yes.
- Marienfelde76Jul 30, 2022Tutor
Realize I'm rather late to this party (sorry ..) but I just got the GUI update note also (July 30,2022) . Not realizing there was a potential issue I blissfully went ahead and downloaded and installed the new GUI version (V1.0.0.423). To my (now) surprise there was no issue with the upgrade and I tried switching from the default English to German (Deutsch), worked fine and had no problem switching back. Since I haven't seen any posts about more recent problems, NETGEAR must have fixed whatever was at issue with it.
- michaelkenwardJul 31, 2022Guru - Experienced User
That was a short term glitch that didn't last long. Some of us didn't even see it.
