dileept's avatar
dileept
Follower
Jul 25, 2022
R7800 Version 1.0.2.90
Hi All,
I have updated my router R7800 to Version 1.0.2.90 and after that it’s keep dropping 5Ghz. Any recommendations on how to fix it or is there a lower stable version where we don’t have issues?
Thanks
Dileep
  • michaelkenward's avatar
    michaelkenward
    What symptoms do you see?
    Does the 5 GHz LED go off? Or is it that wifi clients can't connect?
    Have you enabled Smart Connect?
    I see no issues with my R7800 on that firmware. I'd try a few things before diving into alternative firmware.
