DANNG
Dec 05, 2021Aspirant
R7800 VPN service broken by Firmware V1.0.2.86
The latest Router Firmware Version V1.0.2.86 for the R7800 causes the VPN service to stop working. Creating a new OpenVPN profile doesnt solve the problem. Please advise.
DANNG
Update: The VPN service works. The problem was that the Firmware update did not preserve the MAC address configuration of the router. The update changes the Router MAC Address setting from "Use This MAC Address" to "Use Computer MAC Address" This caused our router to be assigned a random DHCP address instead of the Static IP it should have been assigned.
Dec 05, 2021Guru - Experienced User
Did you factory reset the router after the new FW was installed and then setup from scratch?
