yrogerg77
Mar 21, 2022Aspirant
R7800 Wi-Fi won't come back on after power shutoff
I am having a sudden issue with my 2 year old Nighthawk router. Today I had to shut my power off for some unrelated maintenance, but once I turned everything back on, I noticed my wifi network is dow...
michaelkenward
Mar 22, 2022Guru - Experienced User
yrogerg77 wrote:
I am having a sudden issue with my 2 year old Nighthawk router. Today I had to shut my power off for some unrelated maintenance, but once I turned everything back on, I noticed my wifi network is down.
What modem/gateway sits on front of the router?
When you rebooted the network, did you follow the recommended order?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
yrogerg77
Mar 22, 2022Aspirant
My modem is a Motorola MB7621.
Why would turning them on in a certain order affect my wifi antennas? No, I did not bother with doing things in a certain order. I have had power issues in the past, and when power is restored things have always worked fine when they boot up together previously.
I assumed that things would be OK here too, however maybe part of the router got fried somehow? I've never had this happen before all my years of home networking...
- michaelkenwardMar 22, 2022Guru - Experienced User
Why would turning them on in a certain order affect my wifi antennas?The two questions go together.
Some modems also do wifi. (They are modem/routers.) In that case, the start up, order can determine how they configure themselves when they connect as they try to avoid conflicts.
In this case it shouldn't matter. But doing things on the wrong order can have other effects. That's why Netgear sets out the right order. Read the instructions.
Turn the router on before the modem and you can have a dead network.
