ToddPals
Jul 01, 2017Aspirant
R7800 will not hook up to a laptop running windows 10
I am so frustrated. I have a laptop running windows 10 and I can see the netgear router and I am putting in the correct password but my laptop continues to say it cannot connect to the network. Can...
- Jul 02, 2017
Navigate to your routers web page.
Under the Advanced tab, navigate to Setup, then Wireless setup. You'll find these settings here...
I use UpTo300Mb on 2.4Ghz, manual channels 1, 6 or 11 and WPA2 and AES only.
Does your Laptop connect to the router with a LAN wired cable?
michaelkenward
Jul 02, 2017Guru - Experienced User
ToddPals wrote:I am so frustrated. I have a laptop running windows 10 and I can see the netgear router and I am putting in the correct password but my laptop continues to say it cannot connect to the network.
Is this a wifi connection?
