Qu32's avatar
Qu32
R7800 will not take static IP address entry
I can not get my new R7800 to accept a static IP address entry. It keeps coming up with an invalid IP address entry warning message. My R7000 router set up and works perfect using the same static I...
  • Qu32's avatar
    Qu32
    Aug 01, 2016
    Just wanted to let you know that I got it figured out, problem was in my set up at the mixer end.
    As for the reason the static IP works better than DHCP I don't really know other than it really does help.
    the Ipad itself never would disconnect but the mixer control app would.
    The wifi link between the mixer and the Ipad is only for control data, no program audio is carried over the wifi.
    Mike C.
