mansus
Aug 30, 2016Aspirant
R7800 wireless clients cannot connect to lan clients
Hello, I have the latest firmware 1.0.2.04 on R7800 and have an issue where my wifi client cannot access servers on lan on the same router. I found suggestions about firmware resets and turning o...
- Nov 22, 2016
evel I'm using Kong Mod from myopenrouter.com. It's a straightforward process on how to replace the firmware (just look at the latest article). For VLAN tagging, you'll need to create a VLAN on eth0 (default WAN) interface (Setup->Networking) and assign a newly created port as WAN port on the same page. Once you're online - you can easily do the rest (wifi, services, etc). WIFI->LAN works right away.
Thx, Mansus.
Retired_Member
Aug 30, 2016None of those are using Guest?
It shouldn't be happening, the only thing to due is reset to defaults and or try another FW
- mansusAug 31, 2016Aspirant
Nope. None are using guest. Actually I tried guest wifi with enabled option to be able to see other clients but that didn't help either.
- Retired_MemberAug 31, 2016
Use Ping to see if you can ping a LAN device from a WIfi
- mansusSep 02, 2016Aspirant
Can ping no problem but none of the LAN resources are available on any of LAN clients (SMB, HTTP, RDP, etc). Seems to me a bug in a firmware (it was already reported as fixed in one of the previous versions but looks like it's back).
- VE6CGXSep 30, 2016Master
Did you set up home group if you are on Windows OS? Anything user password protected individually? Easiest thing is setting up
home group to share things such as files, pictures, music, etc.
- evelSep 30, 2016Aspirant
I'm good on the sharing. My shares worked fine until the firmware update and configuring a VLAN ID for CenturyLink fiber.
I cannot access shares, RDP, Roku remote (from an android device), load web admin page or telnet to 80 on my NAS.
I did a wireshark trace while trying to access a share. Now, I am far far from being a pro capture reader, but I get random resets and TCP RTO of 9.3 secs. The session ends with HTTP 405's.
I'm going to try a few other things and see if I get similar results
