mansus
Aug 30, 2016Aspirant
R7800 wireless clients cannot connect to lan clients
Hello, I have the latest firmware 1.0.2.04 on R7800 and have an issue where my wifi client cannot access servers on lan on the same router. I found suggestions about firmware resets and turning o...
- Nov 22, 2016
evel I'm using Kong Mod from myopenrouter.com. It's a straightforward process on how to replace the firmware (just look at the latest article). For VLAN tagging, you'll need to create a VLAN on eth0 (default WAN) interface (Setup->Networking) and assign a newly created port as WAN port on the same page. Once you're online - you can easily do the rest (wifi, services, etc). WIFI->LAN works right away.
Thx, Mansus.
mansus
Sep 06, 2016Aspirant
storm1985, thank you for your input. However why would it "should" work? Ping runs over icmp protocol which runs over udp. HTTP, SMB run over TCP/IP. For example, I'm trying to RDP to another PC. And the first phase is successful - e.g. it prompts me for the credentials. However after credentials are entered the connection fails within some seconds with an "internal error has occurred". But accessing the services on the router (e.g. router gui) works just fine. Ergo it does seem like a firmware issue to me.
