mansus
Aug 30, 2016Aspirant
R7800 wireless clients cannot connect to lan clients
Hello, I have the latest firmware 1.0.2.04 on R7800 and have an issue where my wifi client cannot access servers on lan on the same router. I found suggestions about firmware resets and turning o...
- Nov 22, 2016
evel I'm using Kong Mod from myopenrouter.com. It's a straightforward process on how to replace the firmware (just look at the latest article). For VLAN tagging, you'll need to create a VLAN on eth0 (default WAN) interface (Setup->Networking) and assign a newly created port as WAN port on the same page. Once you're online - you can easily do the rest (wifi, services, etc). WIFI->LAN works right away.
Thx, Mansus.
evel
Sep 19, 2016Aspirant
I am having the same issue.
I have multiple wireless devices that cannot access LAN resources.
I can ping the wired resources but:
1. Cannot access a wired NAS device from wireless devices. Wired can access it fine.
2. Cannot control a wired Roku3 from my android phone over wifi
3. Cannot RDP to my wired desktop from my wifi laptop
Again, ICMP is fine. Anything else will sit and spin until it times out.
It was working fine until I updated to the latest firmware. 1.0.2.04
I also starting using it with a fiber connection and setup a VLAN bridge group.
